Topic: QR read from WIatag + GEofence
HEllo,
Can be improved notification that would include;:
QR read by WIatag + inside GEofence
Thanks
HEllo,
Thanks
locationGPS, explain your idea in more details, please. What problem do you face and how the suggested solution will help?
I need to set a command to device in case the QR code was read by wiatag inside the Geofence...
You can attach a QR Scanner to a device and then apply any logic you want.
Regards
the Logic is what I asked for; "QR reading inside GEofence"
thanks
thanks
Hello!
If QR code is number value you can try to use notification control geofence + option 'Sensor value'
Notification can trigger when unit is inside geofence and send controlled value of QR code.
the sensor value "text" does not fit + GEofence, alrady check everything.,.
thanks
