Topic: Teltonika FMB120
Hello Teltonika fans
We quit using Teltonika FM1100 four years ago because of constant freeze issues. Some of them still running without problems so why some work and some don’t are still a mystery for us.
Anyway, 4 years had passed and we thought to test their new product line FMB120 with fancy FOTA and everything. So we took 100 devices for testing.
Big was our surprise if after 100 test devices were installed it turned out that 10% of them had random freeze issue (every 10-th device froze).
Wow 4-5 year of research and development and Teltonika still could not figure out how to fix the freeze issue described here: https://forum.gpsgate.com/viewtopic.php?t=14754
Could not believe my eyes. One of our clients could drive only 1 hour and a total 20 kilometers after installation and the device froze in the middle of driving.
The info is simply put here to warn everybody whoever wants to use Teltonika devices then you have to consider that you are buying literally ticking time bombs and you never know when they go off.
If you want to have constant issues then yes Teltonika is the right product for you. But if you want to run carefree service then any odder device is better than Teltonika. That’s our experience.
We have tested several made in CHINA devices but currently, FMB120 outperforms all of them and not in a good way.
Appreciate if you can share your experience here regarding Teltonika FMB product line.
