error 7 "reason": "OPERATION_NOT_ALLOWED"
Тема: error 7 "reason": "OPERATION_NOT_ALLOWED"
Hello,
i try to use the API to change current token access type flag value with "eid" from json file :
but i get error 7 ("reason": "OPERATION_NOT_ALLOWED: for 'update' operation you should be authorized) as a response (check the joined file)
Best reguards
Re: error 7 "reason": "OPERATION_NOT_ALLOWED"
iheb.balti пишет:
Hello,
Best reguards
Hello!
Please check token access with which you login -  parameter access_type
To change token you need to have full access
Please note you can  get token with full access through authorization page , just specify parameter access_type = 1
Diana Cheley
Wialon Hosting Expert
