Topic: Get list of Journey
How Can I get list of journey based on driver.?
i.e. If login with a specific driver I need list of journey assigned to that Driver. How Can I achieve this?
Hello!
could you please specify what do you mean to login with a specific driver : login into mobile Logistics app or just login to system as simple user?
Also what do you mean about journey - route in Wialon, orders in Logistics or something else?
samir.agile wrote:How Can I get list of journey based on driver.?
Hello!
Yes login driver using : login into mobile Logistics app
and Journey means route route in Wialon
these two parts are not connected with each other
Routes is separate module which doesn't effect to Logistics app
Also our Logistics app mobile is not open-source, so you cannot implement some new feature using SDK
You need to developer own your mobile app
samir.agile wrote:Yes login driver using : login into mobile Logistics app
and Journey means route route in Wialonthese two parts are not connected with each other
Hello,
I mean we are not going to use logistics app, we need to develop our own app where Driver can login and after login driver can see list of routes assigned to him.
Is it possible? How can we achieve this?
chdi wrote:samir.agile wrote:Yes login driver using : login into mobile Logistics app
You need to developer own your mobile appHello,
Hello!
as some simple way you driver can login into mobile app as simple user which you create in Wialon
or you can create some common user which has access to all drivers (from all resource for example), then login under user's token, but after provide information (sort it) only for particular driver depend drivers information, for example name or phone number
