Topic: Work time and Rest time of Driver
Hello all
How can i configure work time and rest time of driver. Because our driver's rules are different EU rule.
Hello all
We also would like a way to configure this time for drivers. Here in Australia they can drive maximum of 17 hours in any 24 hour period. This can be done in any form or 17 hours straight.
Hello, we also have been requesting this option for a while, without response.. This is a must for us in Central America region. Hope finally this request is approved and developed ASAP
Best regards,
In Iran we have special rules for this and it's really interested for us also
Dear partners
We're working on new tachographs solution for Wialon.
It means new application for processing the data from digital tachogrhaphs (it's used in EU, CIS)
In the USA tachogprphs are not required (ELD service) and it's a little bit the other mechanism of data colllecting and processing
To collect more information about the rules in your region (devices for getting data, laws, some additional notes) please send all information to hw@gurtam.com
Thank you.
Hello Yavi and thanks for your prompt response... Notice that we DO NOT use tachograph as in Europe, we want to get this information setting the required parameteres manually (so the system can do the calculations); you have to do this development to able us to set the required parameters, should be in "Billing Plans" on CMS, so we set the "desired" parameters and it will apply to all the accounts under that billing plan, (note that we can edit those parameters anytime if we wish). If anyone has a better idea, please post it.
Same situation here...
It can be in each unit's properties in my eyes.
At first we need to get some parameters (activities of driver). For example, some device should send the parameter of driving (rest, maintynance or other work).In the USA such functions are made by special ELD mobile aplications which are approved by goverment structures. After that we can discuss analyzing it in Wialon.
yavi wrote:
At first we need to get some parameters (activities of driver). For example, some device must should send the parameter of driving (rest, maintynance or other work).In the USA such functions are made by special ELD mobile aplications which are approved by goverment structures. After that we can discuss analyzing it in Wialon
Cant you use Driver Binding sensor? Any parameter can be used as it's parameter.
Hello,
I am needing for the clients that the Tacho View application be able to adapt to the existing regulations in the Balearic Islands and also in the Canary Islands.
I attach the following note from the UETR.
In the case of the Balearic Islands, in Mallorca, Ibiza and Menorca.
In the case of the Canary Islands, in Gran Canaria, Tenerife, Fuerteventura, Lanzarote, La Palma, La Gomera and Hierro.
The new Royal Decree approved by the government translates into a flexible regime for the aforementioned islands, the exception of Mallorca, attention to the singularity of island territories, in which short journeys and inter-island journeys predominate and in some cases , strong seasonality of low and high demand for transport services. The flexible regulation is applied both at rest and can also be divided as one of the blocks of rest sea of at least 8 uninterrupted hours, to the reduced weekly rest that can be taken during 3 consecutive weeks and to the breaks in the driving of 45 minutes that are can split into three blocks of at least 15 minutes.
YAVI: we use iButton (avl_driver) for binding drivers, you can get the "working parameters" from it?
jhdeguate in theory it can be. But there are so many nuances.
For example, not all trackers send ibutton values in all messages.
Also it can idicates the values the statuses as "driver inside" - "driver outside" only. Usually regulations need more statuses (like work without driving -- like loading, or customs procedures, or service of vehicle).
