Topic: Iridium Extreme 9575
[Synchronize Data to Device] command sends the following configuration parameters to LBS Portal:
- Distribution Lists
- Reporting Frequency
- Emergency Destination
- Emergency Call Recipient
- Protocol Type
- Canned Messages
Fill up the parameters you need in Device Configuration in Wialon.
The following parameters are available:
"Synchronize Distribution Lists"
"Distribution List 1"
"Distribution List 2"
"Distribution List 5"
"Synchronize Reporting Frequency"
"Reporting Frequency Rate"
"Reporting Frequency Rate Units"
"Synchronize Emergency Call Recipient"
"Emergency Call Recipient"
"Synchronize Emergency Destination"
"Emergency Destination"
"Synchronize Protocol Type"
"Protocol Type"
"Synchronize Canned Messages"
"Canned Message 1"
"Canned Message 30"
[Synchronize Data to Device] sends all filled in parameters to LBS Portal in one message.
Alternatively, the following commands are available but not recommended:
- [Set Distribution List]
- [Set Reporting Frequency]
- [Set Emergency Destination]
- [Set Emergency Call Recipient]
- [Set Protocol Type]
- [Set Canned Messages]
