Issue with the Gurtam Maps application
Topic: Issue with the Gurtam Maps application
We wanted to use the Gurtam Maps app code, which is in GIT, but at the moment of executing, it sends us this error code:
hst-api.wialon.com/gis_render/36_20_11/12243390/tile.png:1 GET https://hst-api.wialon.com/gis_render/36_20_11/12243390/tile.png 401
The fragment that we detected that initializes the map is the following:
        * Initialize map (Leaflet)
        * Added handler on click and some one, setting of map
        var _initMap = function(){
            // create Gurtam Maps layer
            app.sections = [];
            var gurtam = L.tileLayer.webGis(wialon.core.Session.getInstance().getBaseGisUrl('render'), {
                attribution: "Gurtam Maps",
                minZoom: 4,
                userId: wialon.core.Session.getInstance().getCurrUser().getId()
            // create map object
            MAP = L.map("map", {
                center: [53.505,28.49],
                zoom: 6,
                layers: [gurtam],
                doubleClickZoom: false,
                dragging: true
            maps = MAP;
            ROUTE = L.polyline([], {color: 'red'}).addTo(MAP);
            MAP.on('mouseup',function(e){
                MAP.removeEventListener('mousemove');
            MAP.on("click", function (evt) {
                var $input;
                /* jshint eqeqeq: false*/
                if(_activeTab == 'tab-search'){
                    $input = $('.search-point.selected');
                    $('input.address-input').removeClass('selected');
                }else{
                    $input = $('input.address-input.selected');
                _searchBlock();
                // var $input = $('input.address-input.selected');
                if($input && $input.length){
                    show_marker(evt.latlng, false, $input, true, function(){
                        $('.add-point').trigger('click', true);
                        _searchBlock();
            MAP.on("dblclick", function (evt) {
                var $input, cb = function(){};
                /* jshint eqeqeq:false */
                    $input = $('.search-point');
                    if($input.length){
                }else    if(POINTS.length >= 2 && !$('.find-address').val() && POINTS.length < MAX_POINTS){
                    var notFillInputs = _.filter(POINTS, function(point){ return !point.lat || !point.lon; });
                    if(notFillInputs.length){
                        var id = notFillInputs[0].id;
                        if(id)
                            $input = $('.point[data-point-index='+id+']').find('input');
                    }else{
                        $input = $('.find-address');
                        cb = function(){
                    _searchBlock();
                        show_marker(evt.latlng, false, $input, true, cb);
                }else{
                    app.notify.add($.localise.tr('You have reached the limit of points.'), true, 'error');
We do not know what could be happening. Could you help us identify the problem?
We wait comments
Re: Issue with the Gurtam Maps application
Hi Denisse
The code on github was outdated.
Just updated https://github.com/wialon/wialon-app-gurtammaps, everything works for me, please check.
Thanks for reporting!
Thank you so much for this support.
I'm just posting to get my 5 posts so I can ask the question I really need answered.
-Eron
Skype: eron.iler
Fleetistics.com
Hello!
Please specify your questions regarding this topic
Diana Cheley
Wialon Hosting Expert
Hi,
We are using the app GurtamMaps with the code in github but we are want to know if posible to change of GurtamMaps Layer for GoogleMaps  Layer and add of provider googlemaps for calculate route?
