Тема: Sensor display last good known value
Some vehicles provides Zero value from FMS then in sleep mode and even worse some provides max value which distorts the data in sensors. If we use min max function then in main window it shows N/A this is non sense because client sometimes needs to see odometer instantly. Maybe you can add some kind if check on sensors. Remember last ignition ON value.
