Topic: Analog or Digital fuel sensor?
I want to know which type of fuel level sensor in better analog or digital? IN DIGITAL which is better RS232, RS485 or can bus type interface?
Digital (RS232, RS485, CAN) is better because it is "loseless". Tracker receives either correct message from sensor or does not receive anything.
Analog signal can be affected by bad wiring, bad "ground" contact. Also resolution of sensor in most cases is limited by ADC properties of GPS tracker.
So we highly recommend to use digital interfaces for fuel monitoring.
RS232, RS485 and CAN will provide same precision, only difference that RS232 allows only one device to be connected while RS485 and CAN allows to connect several sensors.
Thnx for your clear reply. How adc properties affect sensor resolution? I read some where that digital sensor can message fill up and drain events and analog can't, what is that?
If FLS is giving 98% accuracy for 300 l tank what does that mean? FLS can read below 6l fluctuations or not?
Sorry for the roughing questions.
it is a normal, more than 50% FLS users do not understand accuracy correctly.
Accuracy of level sensor - it is accuracy of level measurement, not volume. If sensor has 1% accuracy that means that it measures fuel level with 1% error in static condition (not moving) and with heating and cooling of sensor during all temperature range.
(It does not count temperature expansion of fuel itself because level changes due to temperature expansion of fuel depends from the tank shape. But temperature expansion is almost compensated by dielectric constant changes of fuel itself during cooling/heating. So, good fuel level sensor must have stable properties during cooling/heating and it solves the problem of temperature.)
But customers always interested in volume measurement, right?
This accuracy depends from several factors:
1. Sensor accuracy (see above)
2. Tank calibration accuracy (depends from installer)
3. Tank shape (wide and low-height tank will generate more error than vertical tank, irregular shape will generate more error than regular)
4. Vehicle operation (uphill/downhill, in combination with irregular tank)
We usually talk to our customers these info:
In the Wialon you will see the current volume in the tank with 1% error (99% accuracy) calculated from the full tank volume
for example, for 100 and 500 liters tank you will have +/-1 and +/-5 liters error.
How Wialon calculates filling and theft volume : as a difference from 2 fuel volumes.
that mean we have double error (from 2 volume measurements). and error of filling/drain volumes will be +/-2 and +/-10 liters accordingly.
it is a worst case though(double error).
Note, that this error does not depends from the filling/drain volume. NO matter, filling was 100 or 10 liters, error is same.
This model is very close to reality.
About ADC error :
Lets say GPS tracking device has 10-bit ADC which gives us 1024 points of resolution
But this analog input have 0-30V range.
Typical fuel level sensor with voltage output has 0-10V range (or even 0-5V)
so it is use only 1/3 or 1/6 of ADC range, and same part of this resolution.
for 0-10V sensor we still have only 300 points of resolution which is worse than sensor can provide, so we limit the sensor precision.
I still think if it's 1% error in measurements than it should be 1% of measured length not the full length. Like if length of FLS is 500mm and 1% error will be 5 mm for full length and 1 mm for 100 mm filling length.
Digital FLS can provide data for fuel in fill and drain, what does that mean? If overall accuracy for theft will be 2% than for 500l tank 10l will be error count. If that is true any driver can easily bypass FLS readings.
Please provide info regarding ADC in connection with FLS length or fuel volume for my better understanding.
I really appreciate your knowledge and help.
You are right! But you are talking about length, it is useless for customer. They need volume. Volume error better calculate from full tank volume.
About drain detection by FLS. Wialon has much more possibilities to detect fuel drain than sensor - speed data, vehicle position, sensor data, time etc.
Sensor can't make drain detection better than software.
It is used for emergency notification. Because Wialon detects fuel theft with delay (3-10 minutes). It can be very long if fuel is stolen by another person (not driver). Information about fuel theft is useless because it is evidently that fuel was stolen (driver is a first person who will say about it). We need instant driver notification to catch the thief.
So our sensor has alarm output as a bonus which can be connected to the alarm input of GPS. (rs485/rs232 can't work as alarm). And gps tracker will activate voice call/sms during robbery.
but volume of robbery will not detected.
to calculate how bad is analog interface for fuel monitoring you need to have data:
1. ADC resolution and input range of analog input of gps tracker
2. voltage range of fuel sensor after cutting (some can be recalibrated some not).
approx initial resolution of cutted sensor is 1000 points per length (in theory, you can measure 0.1mm level change in very best case, 0.1%)
than calculate of analog input resolution : 10 bit =1024, 12bit=4096, 8 bit=256
than calculate which part of analog input you will use : sensor range/input range. lets say 10volt/30 volt=0.3
and you will see the smallest level change you can feel by sensor:
0.3*1023=300 points per height, for 500mm sensor it is 1.6mm delta. You will not see fuel change of 1 mm height.
it does not mean that driver can take 10 liters and you will not see it.
I described it as MAX fuel event error. Driver can make several fuel thefts of 10 liters and you will have these data as example:
7,12,8,3,16,9, 10 liters
So we should be careful in choosing the GPS Tracking Device, right?
And the most important thing is to choose a Fuel Level Sensor as accurate as possible.
This SOJI Analog Fuel Leve Sensor can achieve 99.5% accuracy, a really good bang for the buck.
mechatronica wrote:dielectric constant changes
Looks like typical fooling from manufacturer. 99.5% of WHAT?
