Nearby feature in Wialon Mobile
Тема: Nearby feature in Wialon Mobile
Hi ,
As a fleet manager user , we would like to see Nearby feature . Typically private fleet managers want disptach a Nearby available vehicle /unit , as replacement or on demand .
Would expect feature to work something on following lines
User
1) Search's for a Unit based
- on his location ( Wialin App Geo location )
or
- on a Unit's location
2) App would be expected to list Nearby units based on distance
3) User will be able to see desired Unit driver mobile number for call  and if available ,  instruct him to proceed to Unit or Location as defined in 1)
4) Live Link between 2 units / locations to be made available  for 30 or 60 or user define-able time to be  made available and User may share the same over WhatsApp between 2 units/ drivers .
Cheers
Re: Nearby feature in Wialon Mobile
rajeev@albasmart.com, may be you can use this tool?
Hi shal ,
Thanks for quick response . Is it possible to a hieve this achieve this in Wialon Mobile App
Cheers
rajeev@albasmart.com, you can login to Wialon interface from mobile. But why do you need nearest units feature in mobile app?
Login from Mobile for Wialon interface is difficult . A lot of Fleet Management Supervisors are on field and wish to use a simple Mobile UI for filtering nearest available unit/ vehicle and disptach to the customer location . we can use Google real time traffic api's we can exactly know driving time and distance between two units
Cheers
