temp sensor issue
Тема: temp sensor issue
Hello gurtam forum,
I have buy some temp sensor with bluetooth.
But i have a problem to the sensor of the unit.
The problem is that the sensor return me temp * 100, like 2800 C.
So in the parameter of the sensor i wrote (io25)/100 but it doesnt work.
I also tried (io25)/(100) and again nothing.
Any suggestion?
temp sensor issue
Re: temp sensor issue
ldibra there is a possibility that this parameter is transmitted as Text field (mathematical operations are not available this way).
Please specify your tracking device type and parameter's name which you are talking about.
Thank you.
Viktor Yarovenko
Business Analyst
Wialon
temp sensor issue
yavi пишет:
Thank you.
Im using teltonika FMB120, and the parameter is io_25
temp sensor issue
ldibra пишет:
Try io25 / const100
temp sensor issue
rual пишет:
ldibra пишет:
Try io25 / const100
its ok now.
Thanx a lot
