Topic: GPS Traveled distance between two Intervals time(From and To)
Hi ,
I want to display the vehicle traveled distance(Kms) between from and to time(custom time).
Please suggest any reference.
Hi ,
venujakku, please, use the report/table result. an example is https://sdk.wialon.com/wiki/en/sidebar/ … es/reports
Dear Vota,
Thank you for reply.
Right now I am calculating distance using from report tables.
But, I am getting 1003 error(Only one request is allowed at the moment) codes after 5 minutes and not getting results.
One of support team member advised me to use events. But, I could not find the related API reference to calculate the distance traveled between time intervals.
https://sdk.wialon.com/wiki/en/kit/remo … events/get
Please advice me with an reference to avoid 1003 error.
Hello support,
With the new feature for displaying battery level may I know how to set it up. I have managed or included it on monitoring panel but no bars inside the battery.
venujakku,
You can use events to get the "timestamps" for the beginning and end of the trip. Having the pair of events, just request the trip information for such interval.
ntambod, just create Custom sensor for unit and type message parameter that contains value of battery level. If value of message parameter isn't in range of 0-100 make appropriate calculation table.Then select this sensor in Advanced properties of unit Battery level select.
