Topic: VW polo и каншина
Есть ли у кого-нибудь опыт подключения каншины на этой машине без канлога?
Какие параметры удалось получить?
www.gps2010.ru
Kakoj Polo? Platforma/god?
Esli tam ne odin iz samix pervix Polo, to poluchit mozhno vsio chto nuzhno ![]()
61 поло
на днях попробую посканировать
Помогите найти топливо, обороты и температуру
Пробег, двери, тормоз, фары - это я нашел...
CAN-Log....
Saved at 12:22:53 on Пн апр 23 2018
CAN. Start scan
ID=041 (8) 7A 03 00 00 00 00 00 00
ID=050 (4) 00 20 90 B0 FF FF FF FF
ID=0D0 (6) B5 20 00 08 0D 90 FF FF
ID=1A0 (8) 00 40 00 00 FE FE 00 0E
ID=280 (8) 01 22 CC 0C 22 00 17 19
ID=288 (8) 8A 7B 10 00 00 53 93 0F
ID=320 (8) 04 02 35 01 00 08 00 80
ID=35F (8) 3A 01 00 00 00 20 00 00
ID=380 (8) 20 5C 00 00 00 00 98 00
ID=38A (4) 40 00 40 00 FF FF FF FF
ID=390 (8) 03 00 59 00 00 00 00 00
ID=392 (8) 4A 01 00 81 00 00 00 00
ID=393 (8) B7 00 00 00 00 00 00 00
ID=3A0 (8) 0C 03 00 00 00 00 00 0F
ID=3D0 (6) 00 40 08 00 C8 53 FF FF
ID=420 (8) 02 7D 7F 00 08 64 00 04
ID=440 (8) 20 80 00 FE 80 00 1C 09
ID=44C (8) 22 F1 42 4E 58 02 45 C0
ID=470 (8) 40 01 00 46 00 00 00 1F
ID=480 (8) 68 00 3F 3B 18 00 02 76
ID=488 (8) 6B 18 20 7A A6 00 FF 70
ID=48A (8) 7E 0F 01 00 00 00 00 70
ID=4A0 (8) 00 00 00 00 00 00 00 00
ID=4A8 (8) FE 7F 00 30 00 00 10 A1
ID=520 (8) 0D 01 01 32 80 29 46 00
ID=52A (8) 00 00 00 00 00 00 00 00
ID=540 (8) 60 00 FF 00 FF 00 12 EF
ID=550 (8) D0 00 00 00 00 00 00 D0
ID=570 (5) 87 24 BC 00 80 FF FF FF
ID=580 (8) 9B 00 00 0F 0F 70 0C 43
ID=588 (8) F0 6B 7A 00 00 00 04 00
ID=58C (8) 90 A0 23 00 14 00 00 02
ID=58F (8) 00 FD FF 7F 00 00 00 B2
ID=5A0 (8) 7F 00 00 50 00 00 00 2B
ID=5A7 (8) 1D 18 00 00 00 00 00 00
ID=5D0 (8) 80 02 50 2F 39 59 00 00
ID=5D2 (8) 02 47 30 32 30 38 38 38
ID=5DC (8) 6F 00 A0 01 08 00 00 04
ID=5F3 (8) 00 00 8A 00 00 00 00 00
ID=60E (2) 08 00 FF FF FF FF FF FF
ID=621 (8) 20 32 80 35 81 64 FD 00
ID=629 (8) 08 80 D6 41 29 46 40 FF
ID=62B (8) FE 1F 00 40 09 00 FE 7F
ID=62D (8) FE 1F 00 40 09 00 FE 7F
ID=62E (7) 29 46 E0 B0 0A 20 00 FF
ID=721 (7) 04 01 01 00 02 00 00 FF
ID=722 (7) 01 03 05 01 00 00 00 FF
ID=727 (7) 08 01 01 00 08 00 00 FF
ID=728 (7) 08 03 01 24 00 00 00 FF
ID=729 (7) 04 03 11 00 00 00 00 FF
ID=7D0 (8) 54 29 46 E0 B0 0A 20 07
CAN. End scan.
Пробег, двери, тормоз, фары - это я нашел...CAN-Log....
CAN. Start scan
CAN. End scan.
Бак 55л? Когда лог снимали, полный был?
Да, все верно
а где нашли?
ID=320 (8) 04 02 35 01 00 08 00 80 - 53 литра в баке.
Большое спасибо! А какие еще параметры знаете?
...каким способом снимали? Бесконтактно? Галилео?
через галилео 7.0
нет, напрямую подключались
Получилось расшифровать: Топливо, Обороты, Температура, Пробег, двери, тормоз, фары
Кому нужно, пишите в личку...
Написал.
Ребят, может кто знает ID и содержание пакета отправляемого в кан шину при выключении зажигания и вытаскивании ключа?
Если кому интересно нашел пакет который можно посылать когда выключено зажигание но не вынут ключ, чтобы магнитола не отключалась через некоторое время...
Как раз интересуюсь этой темой. Сообщите пакет
Загрузил в сервис, есть данные. Правда база данных на VW на немецком и для гольфа. На скрине только часть.
проверьте километраж ![]()
570 ID в кан шине 500 кбс 0 бит - ключ в замке, 2 бит - ACC, 1 bit - ign, 0B - стартер, 3 bit стартер, 7 бит - двигатель заведен, дублируется в 100 кбс шине- 575 ID
Вот ребята очень интересная статья с хабра о кан шине VW POLO sedan
https://habr.com/ru/post/497140/
У меня есть кан с галилео для машин до марта 2020 и после марта 2020
Данные есть:
АКПП
Двери/багажник/капот
Зажигание
Обороты
Педаль тормоза
Аварийка/поворотники
Ручник
пробег
Капот только в редких моделях
Приветствую!
Не поделитесь расшифровкой?
Данные есть:
АКПП
Зажигание
Обороты
Педаль тормоза
Ручник
пробегКапот только в редких моделях
Приветствую!
давали же ссылку на статью на хабре, там многое разобрано. https://habr.com/ru/post/497140/
Кстати все что расписано на хабре относится к Polo Sedan 2019 года в комплектации Connect.
Статья моя, описан мой авто.
Снимал ли кто с ОБД разъёма данные по топливу.Поло свежий 2019 год.Интересует подключение через OBDLOG, необходимы данные по топливу.
в потоке в обд нет данных, стандартным запросм обд показывает топливо, но не совсем адекватно.
