trailer detector
Тема: trailer detector
Hello,
is there any partner using trailer detection wireless mode???
I mean, truck takes trailer (trailer i mean back part of a truck) and wialon SW shows the trailer number.
this should be detected wireless mode....not by ibutton plugged and so on...
any idea?
thanks
Locating things
trailer detector
Re: trailer detector
Hello! I've just answered you in a private message. Thank you for your inquiry!
Neomatica is a Russian developer and manufacturer of ADM - vehicle and personal trackers for satellite monitoring, wireless sensors and RFID-system.
trailer detector
Guardmagic TRIM-1: Universal trailer identification controller for mobile application: trailers, semitrailers, fuel trailers, agricultural machines etc.
GuardMagic TRIM-1 is the special device for operation in vehicle/fleet management system and is intended to
identification any towed equipments (trailers, fuel trailers, etc) to main tractor.
GuardMagic TRIM-1 is install in trailer and wired connected to main module installed in tractor.
GuardMagic TRIM-1 has inique factory number (module ID) and transmit this unique ID by wire to main module
located in tractor.
GuardMagic TRIM1 has inique factory number (module ID) and transmit this unique ID by wire to main module located in tractor.
GuardMagic TRIM-1 main data:
- power voltage:  9V ...35V DC;
- communication interface: EIA-485;
- operation: full automatic;
- communication model in 485 bus: slave;
- communication speed: 19,200 kb/sec;
- address in bus: 03, 07, 14, 22
- address setting: customer (by switch);
- ID code: factory setting;
- short ID: 12 bits (for address 003);
- standard ID: 19 bits (for addresses 007 and 014);
- full ID: 25 bits (for address 022);
- ingress protection: IP 57;
- connection: by cable
- cable: water (mixed detergents/cleaners), oil, fuel, UF resistence;
- protection: over voltage and over polarity.
Application:
- transportation (trailer identification);
- road fuel tankers (fuel trailer identification);
- agricultural sector (external mechanism identification).
In additional:
·         Protection: over voltage and over polarity;
·         Internal LED: YES;
·         Support standard LLS communication protocol: YES;
·         One and more trailers (module serial connection): YES
Why wired connection:
·         Only wired connection allows 100% correct to identify the fact of trailer connection of the trailer: that trailer is connected to tractor, but nut simply located nearby.
·         Only wired connection prevents false identification of trailer connection when several trailers or tractors are nearby.
  • trailer detector
www.guardmagic.com ;
www.tankercontrol.com;
trailer detector
(28/01/2018 12:05:16 отредактировано GuardMagic)
locationGPS пишет:
1) In wireless mode is not possible to make correct detection of trailer connection to tractor.
By other words in simple samples =
- tractor locate near two trailers,
- two tractors with trailers locate near each other.
2) Only wired system allows correctly and unambiguously identify the fact of trailer connection.
Wired connection can be:
- by special communication bus, as usual EIA-485 (in this way you also can have possibility to install additional sensors in trailer)..
Multi trailers support.
We offer such solution.
You simply connect TRIM-1 module in to bus in which connected your fuel level sensor.
Its all. It will automatical work and will work in Wialon.
- by power line to trailer (or brake light), - offer Squarell Trailer ID System.
Multi trailer support.
Will be need special receiver in tractor and ID device in trailer.
trailer detector
locationGPS пишет:
Hello,
any idea?
thanks
Hello
yes it possible with RFID tag  with or without activator ( depend of the number of trailer in the area . The RFID reader is working with Atrack device for the moment .  Gurtam is working to integrate the solution  I will send you information by email
Best regards
Georges
Georges  Geoloc
