Тема: SDK Remote API Issue
Hello.
We have found an error in the sdk (PHP Remote API) when the name of an object carries an & (ampersand) returns error 4 this is solved by making a urlencode to the json object that belongs to params.
Best regards.
Hello.
Best regards.
Hello cerpas
Thanks for reporting!
I've just updated php-wialon, please check
https://github.com/wialon/php-wialon/co … 2d0012b4ad
Here's my test code
include('wialon/wialon.php');
$wialon_api = new Wialon();
$token = TOKEN;
$result = $wialon_api->login($token);
$json = json_decode($result, true);
$params = array(
'creatorId' => $json['user']['id'],
'name'=>"!*'();:@&=+$,/?#[]",
'hwTypeId'=>13028700, // any HW type
'dataFlags'=>1
$result = $wialon_api->core_create_unit($params);
echo $result;
$wialon_api->core_logout();
Hello thanks for upgrade, works fine.
