Internal ID in CMS
Тема: Internal ID in CMS
Hello,
Is it possible to add internal objects ID in CMS columns?
it would help for support when working with API
thanks
Locating things
Internal ID in CMS
Re: Internal ID in CMS
I'm not sure, that CMS is often used by developers. But all other users would get unnecessary information.
From the other hand search_items request is basic for developers. And it provides you IDs.
Anyone can use it, just insert your sid.
https://hst-api.wialon.com/wialon/ajax.html?svc=core/search_items&params={"spec":{"itemsType":"avl_unit","propName":"sys_name","propValueMask":"*","sortType":"sys_name"},"force":1,"flags":1,"from":0,"to":0}&sid=
Tatsiana Shmihelskaya
Business Analyst, Gurtam
Internal ID in CMS
locationGPS, use custom fields for this.
Internal ID in CMS
we use customs fields already...but it was simple to see it directly as a column.
ok, forget it,
thanks
Locating things
