Topic: Geofence notification
Hello,
it would be better to have option "both" in Geofence alerts
So we do not have to duplicate same alert when client wants both..
thanks
Hello,
thanks
Hello locationGPS ,
Could you give some cases in which you need to have option "Both" in geofence notification?
Best regards,
Every time a truck goes inside an area and I want to know when it leaves the area................................................................................................................................................
example, my truck arrives to a boat in the port, and I want to know
a) When my truck arrived into the boat
b) When the boat left the port to other country
My client´s client must know when their load leaves the country in the boat,
Thanks
p.s.: Asking myself, with so many partners aroung the world,,,,nobody has this need?
locationGPS ,
Thank you for your case.
If you use your variant "both", you will not differ notifications "Unit arrived at geofence" or "Unit left the geofence". Because a text and an action will be the same in this notification.
You said that you needed to know "when a unit arrived or left a geofence". So, at the current moment, the best way to solve your problem is creating two different notifications.
I added your idea to our backlog. But partners can change our decision by their activity and good examples.
you can always add the text depending when goes in or goes out..
ok, we will continue doing the same then
thanks
