Тема: Trailer Identificatin Moduel: Guardmagic TRIM-1
Guardmagic TRIM-1: Trailer identification module.
GuardMagic TRIM-1 is the special device for operation in vehicle/fleet management system and is intended to
identification any towed equipments (trailers, fuel trailers, etc) to main tractor.
GuardMagic TRIM-1is install in trailer and wired connected to main module installed in tractor.
GuardMagic TRIM-1has inique factory number (module ID) and transmit this unique ID by wire to main module
located in tractor.
GuardMagic TRIM-1 main data:
- power voltage: 9V ...35V DC;
- communication interface: EIA-485;
- operation: full automatic;
- communication model in 485 bus: slave;
- communication speed: 19,200 kb/sec;
- address in bus: 03, 07, 14, 22
- address setting: customer (by switch);
- ID code: factory setting;
- short ID: 12 bits (for address 003);
- standard ID: 19 bits (for addresses 007 and 014);
- full ID: 25 bits (for address 022);
- ingress protection: IP 57;
- connection: by cable
- cable: water (mixed detergents/cleaners), oil, fuel, UF resistence;
- protection: over voltage and over polarity.
Application:
- transportation (trailer identification);
- road fuel tankers (fuel trailer identification);
- agricultural sector (external mechanism identification).
