Issue with notification - Automatic turn to Disabled
Topic: Issue with notification - Automatic turn to Disabled
Hello everyone,
i have made a couple notifications via email and everything worked very well. But now i dont receive any email, and when i see the notification it show me : Disable.
I change it to Enable, but after a while its turn to Disable.
There is any explanation about that??
Thanx in advance
(edited by kaippally 31/10/2017 08:18:38)
Re: Issue with notification - Automatic turn to Disabled
You may want to check to see if there is a number entered in Max Triggers in the last screen of the Notifications properties Issue with notification - Automatic turn to Disabled
Nishad Hussain Kaippally
Implementation Specialist, Middle East, Gurtam
"Computer science is no more about computers than astronomy is about telescopes."
Yes that was the problem. I didnt set max. triggers and now it doesnt turn off.
Thank you
ldibras wrote:
Issue with notification - Automatic turn to Disabled    Working with Wialon / Index
Indeed, Wialon is a complex multi-layer solution, which adapts to a client’s particular request and provides a set of necessary tools. As a result, there is no universal scenario of work on the platform, as all settings are configured individually. Our partners definitely appreciate this as everything works exactly how it is expected! However, such diversity causes miscomprehension and prevents our clients from leveraging Wialon to the maximum.
