Topic: Getting Error 4 when calling from C# HttpClient
I am hitting the batch command using C# HttpClient class and keep on getting error code 4 but absolutely the below format is fine.
I am also encoding and sending the payload like below
var content = new StringContent(HttpUtility.UrlEncode(mainParam), Encoding.UTF8, "application/x-www-form-urlencoded");
mainParam is shown below, can you tell me how to fix this issue please ?
svc=core/batch¶ms={"params":[{"svc":"unit/update_device_type","params":{"itemId":16141282,"deviceTypeId":14806641,"uniqueId":"352094082333714","dataFlags":1}},{"svc":"unit/update_unique_id2","params":{"itemId":16141282,"uniqueId2":""}},{"svc":"unit/update_phone","params":{"itemId":16141282,"phoneNumber":""}},{"svc":"unit/update_phone","params":{"itemId":16141282,"phoneNumber":""}},{"svc":"unit/update_access_password","params":{"itemId":16141282,"accessPassword":""}},{"svc":"unit/update_mileage_counter","params":{"itemId":16141282,"newValue":0}},{"svc":"unit/update_eh_counter","params":{"itemId":16141282,"newValue":0}},{"svc":"unit/update_calc_flags","params":{"itemId":16141282,"newValue":1809}},{"svc":"unit/update_traffic_counter","params":{"itemId":16141282,"newValue":0,"regReset":0}},{"svc":"unit/update_image","params":{"itemId":16141282,"libId":0,"path":"/library/unit/default.png"}},{"svc":"item/update_custom_field","params":{"itemId":16141282,"callMode":"create","id":0,"n":"Chassis Number","v":""}},{"svc":"item/update_custom_field","params":{"itemId":16141282,"callMode":"create","id":0,"n":"Fuel Id","v":""}},{"svc":"item/update_custom_field","params":{"itemId":16141282,"callMode":"create","id":0,"n":"Install Date","v":"8/22/2017"}},{"svc":"item/update_custom_field","params":{"itemId":16141282,"callMode":"create","id":0,"n":"Install Technician Name","v":""}},{"svc":"item/update_custom_field","params":{"itemId":16141282,"callMode":"create","id":0,"n":"License Country","v":""}},{"svc":"item/update_custom_field","params":{"itemId":16141282,"callMode":"create","id":0,"n":"License Expiration Date","v":""}},{"svc":"item/update_custom_field","params":{"itemId":16141282,"callMode":"create","id":0,"n":"License State","v":" "}},{"svc":"item/update_admin_field","params":{"itemId":16141282,"callMode":"create","id":0,"n":"Device Type","v":"LT500"}},{"svc":"item/update_profile_field","params":{"itemId":16141282,"n":"brand","v":"TOYOTA"}},{"svc":"item/update_profile_field","params":{"itemId":16141282,"n":"model","v":"COROLLA"}},{"svc":"item/update_profile_field","params":{"itemId":16141282,"n":"year","v":""}},{"svc":"unit/update_sensor","params":{"id":1,"n":"Driver Binding","t":"driver","d":"","m":"","p":"drvr_code_r","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{},\"cm\":0,\"mu\":0,\"pos\":17,\"show_time\":false,\"timeout\":0,\"uct\":0,\"unbound_code\":\"\",\"validate_driver_unbound\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":2,"n":"Operating Time","t":"custom","d":"","m":"hrs","p":"none","f":0,"c":"{\"act\":1,\"appear_in_popup\":false,\"ci\":{},\"cm\":0,\"mu\":0,\"pos\":5,\"show_time\":false,\"text_params\":0,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":3,"n":"Odometer","t":"mileage","d":"","m":"km","p":"io16_const/1000","f":0,"c":"{\"act\":1,\"appear_in_popup\":false,\"ci\":{},\"cm\":0,\"mu\":0,\"pos\":4,\"show_time\":false,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":4,"n":"Power","t":"voltage","d":"","m":"V","p":"pwr_ext","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{},\"cm\":0,\"mu\":1,\"pos\":1,\"show_time\":false,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":5,"n":"Moving Time","t":"custom","d":"","m":"hrs","p":"none","f":0,"c":"{\"act\":1,\"appear_in_popup\":false,\"ci\":{},\"cm\":0,\"mu\":0,\"pos\":6,\"show_time\":false,\"text_params\":0,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":6,"n":"Digital IP2","t":"digital","d":"","m":"","p":"io_3","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{\"0\":{\"c\":0,\"t\":\"Low\"},\"1\":{\"c\":0,\"t\":\"High\"}},\"cm\":1,\"mu\":1,\"pos\":11,\"show_time\":false,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":7,"n":"Digital IP1","t":"digital","d":"","m":"","p":"io_2","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{\"0\":{\"c\":0,\"t\":\"Low\"},\"1\":{\"c\":0,\"t\":\"High\"}},\"cm\":1,\"mu\":1,\"pos\":10,\"show_time\":false,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":8,"n":"Program Ver","t":"custom","d":"","m":"","p":"none","f":0,"c":"{\"act\":1,\"appear_in_popup\":false,\"ci\":{\"12800\":{\"c\":0,\"t\":\"50.0\"},\"12801\":{\"c\":0,\"t\":\"50.1\"},\"12803\":{\"c\":0,\"t\":\"50.3\"},\"12805\":{\"c\":0,\"t\":\"50.5\"},\"12806\":{\"c\":0,\"t\":\"50.6\"},\"12810\":{\"c\":0,\"t\":\"50.10\"},\"12812\":{\"c\":0,\"t\":\"50.12\"},\"12813\":{\"c\":0,\"t\":\"50.13\"},\"13056\":{\"c\":0,\"t\":\"51.0\"},\"13057\":{\"c\":0,\"t\":\"51.1\"},\"13059\":{\"c\":0,\"t\":\"51.3\"},\"13063\":{\"c\":0,\"t\":\"51.7\"},\"13064\":{\"c\":0,\"t\":\"51.8\"},\"13065\":{\"c\":0,\"t\":\"51.9\"},\"13067\":{\"c\":0,\"t\":\"51.11\"}},\"cm\":1,\"mu\":0,\"pos\":12,\"show_time\":false,\"text_params\":0,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":9,"n":"Speed Max","t":"custom","d":"","m":"km/h","p":"io_24","f":0,"c":"{\"act\":1,\"appear_in_popup\":false,\"ci\":{},\"cm\":0,\"mu\":0,\"pos\":9,\"show_time\":false,\"text_params\":0,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":10,"n":"Network ID & Channel","t":"custom","d":"","m":"","p":"io_205","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{},\"cm\":0,\"mu\":0,\"pos\":16,\"show_time\":false,\"text_params\":0,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":11,"n":"Location Area Code","t":"custom","d":"","m":"","p":"io_206","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{},\"cm\":0,\"mu\":0,\"pos\":15,\"show_time\":false,\"text_params\":0,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":12,"n":"Carrier ID","t":"custom","d":"","m":"","p":"io_241","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{},\"cm\":0,\"mu\":0,\"pos\":14,\"show_time\":false,\"text_params\":0,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":13,"n":"Internal Battery","t":"voltage","d":"","m":"V","p":"pwr_int","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{},\"cm\":0,\"mu\":1,\"pos\":8,\"show_time\":false,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":14,"n":"Ignition","t":"engine operation","d":"","m":"","p":"io_239","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{\"0\":{\"c\":0,\"t\":\"Off\"},\"1\":{\"c\":0,\"t\":\"On\"}},\"cm\":1,\"consumption\":2,\"mu\":1,\"pos\":2,\"show_time\":false,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":15,"n":"Device Type","t":"custom","d":"","m":"","p":"none","f":0,"c":"{\"act\":1,\"appear_in_popup\":false,\"ci\":{\"12800\":{\"c\":0,\"t\":\"LT-1100-GP_Script_50.0_NoIP_NoAPN\"},\"12801\":{\"c\":0,\"t\":\"LT-1100-GP_Script_50.1_FL_Kore\"},\"12803\":{\"c\":0,\"t\":\"LT-1100-GP_Script_50.3_DG_Digicel\"},\"12805\":{\"c\":0,\"t\":\"LT-1100-GP_Script_50.5_DG_DigicelTT\"},\"12806\":{\"c\":0,\"t\":\"LT-1100-GP_Script_50.6_FL_AerisGlobal\"},\"12810\":{\"c\":0,\"t\":\"LT-1100-GP_Script_50.10_DG_DigicelAnguilla\"},\"12812\":{\"c\":0,\"t\":\"LT-1100-GP_Script_50.12_DG_Atrams\"},\"12813\":{\"c\":0,\"t\":\"LT-1100-GP_Script_50.13_DG_Giscad\"},\"13056\":{\"c\":0,\"t\":\"LT-1100-UM_Script_51.0_NoIP_NoAPN\"},\"13057\":{\"c\":0,\"t\":\"LT-1100-UM_Script_51.1_FL_Kore\"},\"13059\":{\"c\":0,\"t\":\"LT-1100-UM_Script_51.3_DG_Digicel\"},\"13063\":{\"c\":0,\"t\":\"LT-1100-UM_Script_51.7_FL_Altaworx\"},\"13064\":{\"c\":0,\"t\":\"LT-1100-UM_Script_51.8_DG_DigicelBVI\"},\"13065\":{\"c\":0,\"t\":\"LT-1100-UM_Script_51.9_DG_DigicelCayman\"},\"13067\":{\"c\":0,\"t\":\"LT-1100-UM_Script_51.11_FL_AerisDualMode\"}},\"cm\":1,\"mu\":0,\"pos\":13,\"show_time\":false,\"text_params\":1,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":16,"n":"Event","t":"custom","d":"","m":"","p":"event_code","f":0,"c":"{\"act\":1,\"appear_in_popup\":false,\"ci\":{\"1\":{\"c\":0,\"t\":\"Moving\"},\"10\":{\"c\":0,\"t\":\"On Backup Battery\"},\"11\":{\"c\":0,\"t\":\"Low Power Begin\"},\"12\":{\"c\":0,\"t\":\"Low Power End\"},\"13\":{\"c\":0,\"t\":\"Power On\"},\"14\":{\"c\":0,\"t\":\"Input2 On\"},\"15\":{\"c\":0,\"t\":\"Input2 Off\"},\"16\":{\"c\":0,\"t\":\"Idling\"},\"17\":{\"c\":0,\"t\":\"On Demand\"},\"18\":{\"c\":0,\"t\":\"N\\/A\"},\"2\":{\"c\":0,\"t\":\"Parked\"},\"3\":{\"c\":0,\"t\":\"Ignition On\"},\"4\":{\"c\":0,\"t\":\"Ignition Off\"},\"5\":{\"c\":0,\"t\":\"Start\"},\"6\":{\"c\":0,\"t\":\"Stop\"},\"7\":{\"c\":0,\"t\":\"Input1 On\"},\"8\":{\"c\":0,\"t\":\"Input1 Off\"},\"9\":{\"c\":0,\"t\":\"Emergency\"}},\"cm\":1,\"mu\":0,\"pos\":3,\"show_time\":false,\"text_params\":1,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":17,"n":"Cell RSSI","t":"custom","d":"","m":"db","p":"rssi","f":0,"c":"{\"act\":1,\"appear_in_popup\":false,\"ci\":{},\"cm\":0,\"mu\":0,\"pos\":18,\"show_time\":false,\"text_params\":0,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":18,"n":"GPS Signal","t":"custom","d":"","m":"","p":"sats","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{\"10\":{\"c\":0,\"t\":\"Excellent\"},\"2\":{\"c\":0,\"t\":\"No Signal\"},\"4\":{\"c\":0,\"t\":\"Very Poor\"},\"6\":{\"c\":0,\"t\":\"Poor\"},\"7\":{\"c\":0,\"t\":\"Average\"},\"8\":{\"c\":0,\"t\":\"Good\"},\"9\":{\"c\":0,\"t\":\"Very Good\"}},\"cm\":1,\"mu\":0,\"pos\":20,\"show_time\":false,\"text_params\":0,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":19,"n":"Cell Signal","t":"custom","d":"","m":"","p":"io_21","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{\"0\":{\"c\":0,\"t\":\"No Signal\"},\"1\":{\"c\":0,\"t\":\"Poor\"},\"2\":{\"c\":0,\"t\":\"Average\"},\"3\":{\"c\":0,\"t\":\"Good\"},\"4\":{\"c\":0,\"t\":\"Very Good\"},\"5\":{\"c\":0,\"t\":\"Excellent\"}},\"cm\":1,\"mu\":0,\"pos\":19,\"show_time\":false,\"text_params\":0,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":20,"n":"Idle Time","t":"custom","d":"","m":"hrs","p":"none","f":0,"c":"{\"act\":1,\"appear_in_popup\":false,\"ci\":{},\"cm\":0,\"mu\":0,\"pos\":7,\"show_time\":false,\"text_params\":0,\"timeout\":0,\"uct\":0}","vt":0,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_sensor","params":{"id":21,"n":"SOS","t":"alarm trigger","d":"","m":"","p":"io_3","f":0,"c":"{\"act\":1,\"appear_in_popup\":true,\"ci\":{},\"cm\":0,\"mu\":0,\"pos\":21,\"show_time\":false,\"timeout\":0,\"uct\":0,\"unbound_code\":\"\",\"validate_driver_unbound\":0}","vt":1,"vs":0,"tbl":[],"itemId":16141282,"callMode":"create"}},{"svc":"item/update_custom_property","params":{"itemId":16141282,"name":"img_rot","value":"0"}},{"svc":"item/update_custom_property","params":{"itemId":16141282,"name":"label_color","value":"16711680"}},{"svc":"item/update_custom_property","params":{"itemId":16141282,"name":"monitoring_sensor_id","value":"0"}},{"svc":"item/update_custom_property","params":{"itemId":16141282,"name":"motion_state_sensor_id","value":"0"}},{"svc":"item/update_custom_property","params":{"itemId":16141282,"name":"solid_colors","value":"255"}},{"svc":"item/update_custom_property","params":{"itemId":16141282,"name":"track_solid","value":"255"}},{"svc":"item/update_custom_property","params":{"itemId":16141282,"name":"use_sensor_color","value":"0"}},{"svc":"unit/update_trip_detector","params":{"type":1,"gpsCorrection":1,"minSat":3,"minMovingSpeed":1,"minStayTime":300,"maxMessagesDistance":100000,"minTripTime":10,"minTripDistance":200,"itemId":16141282}},{"svc":"unit/update_fuel_calc_types","params":{"itemId":16141282,"calcTypes":0}},{"svc":"unit/update_fuel_level_params","params":{"flags":0,"ignoreStayTimeout":10,"minFillingVolume":20,"minTheftTimeout":0,"minTheftVolume":10,"filterQuality":0,"fillingsJoinInterval":300,"theftsJoinInterval":300,"extraFillingTimeout":0,"itemId":16141282}},{"svc":"unit/update_fuel_math_params","params":{"idling":2,"urban":10,"suburban":7,"itemId":16141282}},{"svc":"unit/update_fuel_rates_params","params":{"consSummer":10,"consWinter":12,"winterMonthFrom":11,"winterDayFrom":1,"winterMonthTo":1,"winterDayTo":30,"itemId":16141282}},{"svc":"unit/update_fuel_impulse_params","params":{"maxImpulses":0,"skipZero":0,"itemId":16141282}},{"svc":"unit/update_command_definition","params":{"id":0,"n":"Starter Disable","c":"custom_msg","l":"vrt","p":"setdigout1 0","a":16777216,"f":0,"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_command_definition","params":{"id":0,"n":"Starter Enable","c":"custom_msg","l":"vrt","p":"setdigout1 1","a":16777216,"f":0,"itemId":16141282,"callMode":"create"}},{"svc":"unit/update_report_settings","params":{"itemId":16141282,"params":{"speedLimit":0,"maxMessagesInterval":0,"dailyEngineHoursRate":0,"urbanMaxSpeed":60,"mileageCoefficient":1,"fuelRateCoefficient":0,"speedingTolerance":5,"speedingMinDuration":1,"speedingMode":1}}},{"svc":"unit/update_activity_settings","params":{"type":1,"itemId":16141282}},{"svc":"unit/update_messages_filter","params":{"enabled":0,"skipInvalid":0,"minSats":0,"maxHdop":2,"maxSpeed":0,"lbsCorrection":0,"itemId":16141282}},{"svc":"unit/update_drive_rank_settings","params":{"itemId":16141282,"driveRank":{"global":{"accel_mode":"0"}}}}],"flags":"0"}&sid=04c20f654e27911fdad3dabf043bec96
