Wialon Retranslator y VisualBasic .NET
Тема: Wialon Retranslator y VisualBasic .NET
Hola a todos. Estoy desarrollando un escucha TCP para la comunicación con Wialon Retranslator. Aparentemente recibo la información, pero tengo problemas para interpretar el network stream que me llega. Alguien tiene experiencia en esto? Gracias.
Re: Wialon Retranslator y VisualBasic .NET
sergio.botta, try to put flespi channel in between from where you can gather accumulated messages within simple HTTP REST API.
Ok. I will try... Thanks.
I am trying Flespi and it seems excellent.. but now I have a problem with UTC time... Where can I get information on how to translate UTC time (in example: 1507580245) to 24hrs time ? Thanks
sergio.botta
check this https://www.unixtimestamp.com/
Thanks.
I will use this:
Public Shared Function UTCToLocalTime(ByVal UTFTimeStamp As Long) As DateTime
        Dim ddd As DateTime = New DateTime(1970, 1, 1, 0, 0, 0, DateTimeKind.Utc)
        Return ddd.AddSeconds(UTFTimeStamp)
End Function
