Hi axpdreamer!
Please specify where do you need to get information about idling status ? Reports, online notifications, pop-up etc.
For example, if you use report Engine Hours you can create Engine efficiency sensor for unit with parameter of status hydraylic pump (on/off) and chek the following information in the report :
Engine efficiency duration: the duration of attached implements operation (if having engine efficiency sensor).
Engine efficiency idling: engine operation time after deduction of efficiency time (total engine hours subtract engine efficiency duration).
Utilization: percentage ratio of engine hours duration to engine hours rate (engine hours divided by daily engine hours rate indicated in unit properties).
Useful utilization: percentage ratio of engine efficiency duration to engine hours rate.
Productivity: percentage ratio of engine efficiency duration to engine hours duration.
Diana Cheley
Wialon Hosting Expert
