Topic: Testing: groups of parameters for sending custom messages
When sending a non-standard command to a unit the user can save the parameters in the system. Having a number of diverse commands and a variety of tracking devices you try to configure it’s highly probable you’ll get an unordered set of saved parameters. As a result, it may take less time to create the new message than to search for the existing one.
To avoid such a situation we implemented parameters grouping in custom message sending dialog in Wialon beta version. All you need is to create a group, select a target parameter and click on “Save” button to add it to the group.
This way you always know which parameters are to be sent to, say, Teltonika devices and what for.
