Тема: Queclink gv55/gv65 plus freeze
good evening.
i Use wialon platform two devices queclink, gv55 and gv65 plus. Gv55 is connected to positive and negative, while gv65 is also connected to the ignition input. It happens that several times, after 1-2 days the vehicle is parked, when it restarts the device remains sleep. It does remaining sleeping and to re-activate it, I must send the sms command to "reboot" otherwise it will not start again.
I tried to set both "deep sleep" and "light sleep" mode, but the problem remains.
Can you help me with courtesy? Thank you all.
