Adding Fuel Level to Geofence Report
Тема: Adding Fuel Level to Geofence Report
Hello,
While working with a customer who have fuel level sensor I noted there are benefits of adding initial and final fuel level at some areas as below:
1- If the customer knows his fuel station where the trucks must fill from them then he can know at the time of entry and exist the level of fuel at both so if filling occurred the he can notice it.
2- If the customer knows the  areas of fuel thefts then he can knows initial and final fuel levels.
Any user on the system can think the above points are achievable by fuel theft and fillings report I would say that some cases you need to analyze the behavior so you need to see both when there is a theft and when there is no theft!
