no way to get logfile/statistics etc. of ddd file download
Тема: no way to get logfile/statistics etc. of ddd file download
hi dear Gurtam Developers,
i just learned, that the message in rawdata, that files was downloaded, is a virtual message and can not be used in notifications to create an "event".
I need for my customers, who are using ddd file download, a way to report for all vehicles regulary, that files was correct downloaded (with filename etc).
Thanks a lot
Wolf.
Re: no way to get logfile/statistics etc. of ddd file download
Hello, Wolf. I'm not sure, that understand you right, so I'll try to explain what I understand.
Your client has a command with type "Query DDD file (query_ddd)". So he executes the command, gets a file. But the problem is that he don't have a possibility to find some information about these executions such as file names and status. Right?
Tatsiana Shmihelskaya
Business Analyst, Gurtam
Hi Tata,
no.... device sends automaticaly once per day ddd files for driver and for tacho. (2 files).
Problem is, that i need to create a report which shows me for each vehicle for each day the downloaded files (that customer can check that files are regulary downloaded).  So no command, but virtual messages in message window. I tried to use a notification but notifications are not triggered by virtual messages :-(
Wolf.
One more try to find the solution smile
Our hardware specialist says that for some devices they register such parameter as "text": "Tachograph file of size $tachograph_data_size bytes downloaded". And then it can be used in notification "Parameter in a message".
May be it was not done for your device. Could you provide us with a test access to such object or tell you device type?
i wrote to support with all details...
Could you ask them?
Thanks
Wolf.
Problem solved!
Filesnames are now in the Logfiles if you create an event.
You can also use If you need to know downloaded file or not You can use parameter "register_ddd" (1 - if all right, 0 - if not)
Great! Thanks
Wolf.
