Topic: error 5 execute report remote with token
Hello.
I have problems when I try to run a report from a token, but when I run it with an outhHash it works perfectly. The token was created from the master account through a token of the same master account this token was created in wialon simple_login.
Yes, I create tokens from the token of my master account but all these token give me the same error 5 when I run the report. I use the flag -1 to have all the access but it is not working.
I do not know why it does not work and I have come to the conclusion that it is the token of the problem. But I do not know if it is the token master that creates the others or that is wrong.
