Topic: Notification Creation Issue using Remote API
Hi,
Please find that, i am trying to create "Excess Idling" notification using Remote API. I am following below format and its getting created properly if i am using tool like "PostMan" for creating post request. But the same format does not work if we are using (HTTpClient in C#) .
It returns error code 4 which is for invalid input.
Can you please have a look and suggest if we are missing anything while formatting the parameters.
"n":"Test Excess Idling Notification",
"ta":1492598264,
"td":0,
"tz":-18000,
"la":"en",
"ma":0,
"sch":{
"f1":0,
"f2":0,
"t1":0,
"t2":0,
"m":0,
"y":0,
"w":0,
"fl":0
"un":[
XXXXX
"trg":{
"t":"speed",
"p":{
"sensor_type":"engine operation",
"sensor_name_mask":"*Ignition*",
"lower_bound":"0",
"upper_bound":"0",
"prev_msg_diff":"0",
"merge":"0",
"reversed":"1",
"min_speed":"2",
"max_speed":"10000",
"min_idle_time":"15"
"act":[
"t":"event",
"p":{
"flags":"1"
"txt":"Dear Valued Customer,",
"fl":0,
"mast":0,
"mpst":0,
"cdt":0,
"mmtd":180,
"cp":0,
"id":0,
"itemId":YYYYY,
"callMode":"create"
J Prabhu
