Error 8 when using operateAs
(edited by Dennis 18/04/2017 20:39:03)
Topic: Error 8 when using operateAs
With both the JAVA API as well as the Javascript version I get an error:8 whenever I try to use tokenlogin along with the operateAs property.
When I set operateAs to empty/null it does work.
{"token":"*SECRET*","operateAs":"Dennis","appName":"","checkService":""}
Am I doing something wrong?
The token is generated for the nedsoftnl account and it does have this user.
Re: Error 8 when using operateAs
Dennis, user nedsoftnl has access to user "dennis" not "Dennis". May be this is the problem?
No I changed it to Dennis because it was dennis first to check if this fixed it. But both don't work.
Dennis, to use operateAs feature use token with -1 access_type.
