Topic: Best Fuel Monitoring Unit Via ECU
Hello,
Can anyone recommend the best Tracking unit that monitors Fuel readings via the ECU Can Bus?
1. Must have supporting Documents for each vehicle type - Location Of ECU Wire to tap off.
2. Must use Can Reader Clips to read data through the wires. No direct contact with wires.
3. Must have an Unit Configuration Platform to change unit settings - None of this SMS programming.
Must work with Heavy Commercials and popular light commercials.
We have tried a few and they have not work well and fail to read the ECU data, where they are supposed to.
Many thanks in advance.
Glenn
