Change device type using WLP file
Тема: Change device type using WLP file
Hi there
I want to retranslate some units from one server to another server. I export all units and import them to new server. Units are in different types and now we have to change all units types to Wilaon Retranslator. Is there any way to change only unit types with WLP file? Any trick? When we want to import a file with Wialon Retranslator device type then in result device unique ID and phone number are empty.
Re: Change device type using WLP file
Hi,
This is happened to me as well. I cant find solution as well. Wialon should create a software for it.
Thank
Think GPS Think Ocean Tech.
Gurtam, please response...
Hello hhamedk
Today it is possible to edit hardware type in multiple units via API requests or through import tool (if you have separate file for each unit) and manual interactions on web interface ofc.
However, if you don't have such hardware available on your second Wialon Local license, new units will be created with Wialon Retranslator hardware type.
mapl, would you please indicate API to change units' hardware type in batch?
hhamedk пишет:
unit/update_device_type
You need to pass id of Wialon Retranslator (on WH it is 12152) and resend unique id of the device.
rual, thanks dear friend.
