Topic: Fuel Level Notification with Engine ON/OFF
Hi All,
can we create notification when engine is ON and notification generate with fuel level sensor value and when engine OFF notification generate with fuel sensor value ?
Hi All,
Yes you can all you have to do is create them under unit properties click on new and add ignition On & OFF
Dear evanirungu,
I do not ask for Engine ON/OFF only, i want fuel level (Sensor Value) with Ignition ON/OFF notification. Can it possible ?
What device are you using?
Teltonika Fm11
You could look a adding a custom field for the fuel level and then add the custom field to the notification text. The custom field would need to be able to get the fuel level value from the parameter. Only alternative is to send all of the sensor values in the message.
It would be good if Gurtam added custom sensors as one of the items that can be added into te message.
Sorry JohnG i cant understand what you explain.
If I add custom field, how it would get value from ADC ?
i want value from analog sensor when unit engine ON and OFF in notification message.
where is the problem? you create two notifications (one if engine goes on and one if engine goes off), than you add in notification text this "%ALL_SENSORS%" and thats it.
(i think there is also a parameter for adding one specific sensor, read the manual for it)
Wolf.
Thank You wwbusch aka Buwo
Exactly that I want
Nice Post on this topic
well we are getting the same and I added %MILEAGE% also but its showing 0.00 KM every time. what settings we have to do please reply.
You should check mileage counter settings. Activate option "Auto". If counter is set on "Mileage sensor", "Relative odometer" or "GPS + engine ignition sensor", please, check mentioned sensors were added.
How to create a Report template Initial location,Beginning,Initial mileage,Final location,End Duration,Final mileage,Following off-time,Final location,Stop From(End),Stop to(next start Initial location).
Regards,
Baskar Paramasivan
IGQATAR good day
we will answer by email
