Тема: Token based login is not consistent
Hi,
When I try to call the login API(token/login) method, I'm keep getting error code '4'. I have also tried to generate new token,
keep getting same error with new token. Token based login is not consistent now a days. Can you please help me to solve this issue asap.
http://hosting.wialon.com/login.html?cl … duration=0
Note: It was working after some time.
Thanks in advance
J Prabhu
