Тема: Testing: Real-time motion sensor
We offer you the freedom of choice and always find new ways of problem solving in addition to the existing ones.
When standard movement detection methods (by speed) fail due to hardware errors or LBS-service utilization, we suggest you to use real-time motion sensor for Wialon Beta.
The sensor is digital by nature and allows you to create calculation table and set speed, ignition, rpm and other indices as sensor parameters. Moreover, the use of formulas in sensor parameters allow for adequate validation (e.g. if the speed is above 3 km/h, the units is moving, but only when the ignition is on).
Although such hardware is uncommon, regular motion detection sensors are also supported in this case.
