Number of satellites in raw data
Topic: Number of satellites in raw data
Hello,
is it possible to have the number of satellites seen in the raw data?
Is it possible to make export to ´xls, this I saw it on another post but nothing more.
Thanks
regards
Locating things
Re: Number of satellites in raw data
locationGPS, you probably mean the Messages panel?
The number of satellites is not available there, however, it's available in Messages Manager app.
Katerina Alexandrova
Product Manager (Hecterra)
Well. the idea to see the coordinates in CMS is for faster support when doing installations.
I can have this info from wialon platform..
too many interfaces to see the info I could have in one,
thanks
Locating things
You can also see the number of satellites in unit's tooltip. This way you do not need to go to any app.
And after the implementation of coordinates in unit's tooltip, you'll be able to see both the coordinates and the number of satellites in one tooltip. Is it OK?
what is exactly "tooltip"?
Locating things
This one
Documentation
In that case I do not need the coordinates , I am looking in the map where exactly is.
The tool that I know is not to check device in different platforms as by now I have to check Operators platform, HW platform and CMS + Wiaon platform.
We are speaking about optimizing working times. that is the idea to think about.
Thanks
Locating things
locationGPS, what are "Operators platform" and "HW platform"?
Also I would like to ask you to provide us with the list of options you would like to see in "one place" to optimize the work of... of whom exactly (of installers probably as we discussed in our Skype session)?
Hello,
GPRS State ON/OFF               gprs last connection (hour date)
nº satellites (actual satellites)
Link to location / coordinates
DIN 1 - ON / OFF
DIN 2 - ON /OFF
Din X - ON / OFF
Battery voltage
CAN info
Temp info
Ibutton code
tacho info
Regards
Locating things
All of this can be found in unit's extended info, I suppose.
show
Locating things
Please write to support@gurtam.com
They will help you to set up unit's tooltip and extended info.
Thanks.
+1
