SessionID ( SID) - What is the expiration logic and duration behind it
Тема: SessionID ( SID) - What is the expiration logic and duration behind it
SessionID ( SID) - What is the expiration logic and duration behind it ?
For example using my login token I am getting the active SID and I am using the SID for my other service calls, when will my SID will expire or it won't expire at all if I use it periodically ?
Is there any expiration time for SID and if it is yes then is it sliding expiration ?
Thanks in advance
Karthik
Re: SessionID ( SID) - What is the expiration logic and duration behind it
karthik, SID will expire after 5 mins of idle (no requests). Any request with current SID will prolong session.
Thanks Deal, Is there any logic of Client side SID and Server Side SID ? Or all the SIDs are same from system  ?
If I click an App from Wialon I am passing along a SID, can I use that SID to call a remote wialon API ?
karthik, Wialon SID is common for client side and server side.
You can use SID which was passed to app for remote API requests.
