Topic: OBD socket
Hi, anyone know if you can get the following information from the OBD11 socket (RPM, speed, coolant temperature, fuel etc) on vehicles Hyundai H1, Nissan Urvan
Hyundai H1 data are given for the model H2> 2008
Egnition lock;
The key in the ignitionhe
driver's door
Front passenger door
right rear door
Rear left door
trunk
The engine hood
Hand brake
footbrake
fired engine
Serial control and / m SLAVE mode
Webasto
Full time office. Motor.
Full mileage cars
Overall fuel consumption
The fuel level in the tank
engine speed
engine temperature
vehicle speed
The liquid level AdBLUE
Position the gas pedal
engine Load
parking lights
dipped
Distant light
driver Seat Belt
passenger Seat Belt
Nissan URVAN http://transcontrol.com.ua/pdf/CANLOGauto.pdf
Thanks forconnecting the Reply. What is the best tool for PC to OBDII. I want to use Linux CAN Utils for checking CAN Logs and Data Packets. Thanks
Thanks for the Reply. What is the best tool for connecting PC to OBDII. I need to use Linux CAN Utils for checking CAN Logs and Data Packets. Thanks
there are plenty tools for obd2 applications.
from just reading ecu signals to ecu remap.
For reading obd2 protocols i think a simple obd scanner with Bluetooth is enough, also download the torque app and its can provide you for protocol ID of ecu.
