How to configure Auto Tracking to Xexun TK-102
Тема: How to configure Auto Tracking to Xexun TK-102
hii , can anyone me tell how to set auto tracking
as not able to track the device continuously .
click on the link below to view device model
http://gurtam.com/en/gps-hardware/personal/xexun-tk-102
thank in advance
Re: How to configure Auto Tracking to Xexun TK-102
1. begin123456 ( reset all settings to  to default)
2. apn123456 APNNAME ( Set the APN name of your telco)
3. apnuser123456 APNSUSER ( set the username for your GPRS connection)
4. apnpasswd123456 APNPASSWORD ( set the password for your GPRS connection)
5. adminip123456 193.193.165.165 21057 ( set the Wialon hosting IP and port)
6. t030s***n123456 ( sets the report time interval to 30 sec ; minimum is 5 sec and max is 30sec)
+ 123456 is the default password , if you have changed it use the password you have st
+ APNNAME / APNUSER / APNPASSWORD depends on your connection , use the ones applicable to your connection)
+ you do not need to send command 3 and 4 if your GPRS connection does not require a username and password
Sint
thanks for reply
will inform you once i completed
ysv  GOOD
Great !
Sint
