Topic: Novatel Wireless MT4000
hii ,
how active novatel wireless Mt4000.
Does any wialon partner can help me to have this software and proper instructions, help me to put this device on
hii ,
Hello ,
thank you for the manual
i have more question for this devices .if you can help me .
if you have a technical support .
please do send me your skype ID
Hello Khaidoo,
have you found informations to get MT4000 working with Wialon?
My problem is I can see the unit online but nothink else in the web gui.
Actual configuration is:
AT$FRIEND= 1,1,"193.193.165.165",21142,3
AT$TCPAPI=1
AT$TCPIDLETO=3600
AT$TCPRETRYTO=120
AT$wakeup=1,28
AT$EVTIM1=120
AT$EVENT=12,1,12,1,1
AT$EVENT=12,3,43,1,0
AT$EVENT=12,3,52,0,4166
AT$EVENT=14,0,0,0,0
AT$EVENT=14,3,52,0,4166
AT$areg=2
ATS0=2
I need a working script for this unit to work well with Wialon
Hello Khaidoo,
My problem is I can see the unit online but nothink else in the web gui.Actual configuration is:
AT$TCPAPI=1
AT$TCPIDLETO=3600
AT$TCPRETRYTO=120
AT$wakeup=1,28
AT$EVTIM1=120
AT$EVENT=14,0,0,0,0
AT$areg=2
ATS0=2I need a working script for this unit to work well with Wialon
Good day!
Try this configuration:
AT$TCPAPI=1
AT$TCPIDLETO=3600
AT$TCPRETRYTO=120
AT$wakeup=1,28
AT$EVTIM1=120
AT$EVENT=12,3,52,0,3694349
AT$EVENT=14,0,0,0,0
AT$EVENT=14,3,52,0,3694349
AT$areg=2
ATS0=2
I changed bit mask at event. Also, you can write to hw@guratm.com
Sorry albu,
no luck with your changes.
The unit is ONLINE but no data is displayed on the web interface.
Any suggestions?
Sorry albu,
no luck with your changes.The unit is ONLINE but no data is displayed on the web interface.
Any suggestions?
Please, write to hw@gurtam.com and also, provide device ID.
Thank you.
Hi why don't you try to use this command AT$FRIEND= 1,1,"193.193.165.165",21142,1 (1 = communicate via TCP only).
Sometimes when you use AT$FRIEND= 1,1,"193.193.165.165",21142,3 (3 = communicate via TCP/UDP and sometimes device is confused.)
What will be the time interval?
A.
