Zoom over objects group
Topic: Zoom over objects group
Hello,
it would be good this improve, when having 1 icon defining several objects, when clicling on it it would Zoom all of them on map.
Also, clicking on each of them could do the same options as being alone. Opening options and so on..
Thanks
  • Zoom over objects group
Locating things
Re: Zoom over objects group
locationGPS, there is tooltip with all group's units on mouse hover.
May be it is enough to add possibility to click on each unit in tooltip? Map will zoom and center on this unit and unit's menu will open after click.
Hello,
I am thinking dispatcher user which has 500 objects in groups over Europe and could not even click as you say but also to make zoom clicking the group the see all the objects that are in the area.
With this Zoom he will fast way see the object he wants nearer a specific place with one view.
Thanks
Locating things
locationGPS, if the dispatcher needs to find units nearest to certain place, I would recommend to use special tool with the same name — Nearest Units.
Katerina Alexandrova
Product Manager (Mobile)
They are different things, if you have big screen they like to see directly not to find this tool and look for it.
Locating things
locationGPS, I wonder how you would like the following feature: when you click on clustered icon, the map is zooming automatically to show all these units.
Hi,
How I would like?  well, you click and then the zoom opens only to those objects. do not know where is the problem.
i do not understand the question sorry.
Locating things
This new feature with clicking on the grouped icon to zoom on grouped units will soon be released.
So, if what I say is still not clear, don't worry — soon you'll have a change to try and appreciate it yourself.
deal.
thanjks
Locating things
Now available for testing in beta version.
alek, where do we or can we access beta site? Curious to check this out ourselves. smile
Onwards and Upwards!!
Knowledge, data & information is power!
FleetPursuit, you can check it on dev.hosting.wialon.com or switch to Beta branch one of your DNS in CMS Manager.
A new feature has been implemented for better usability: when you click on the icon of grouped units, the map moves and zooms to show all of them.
Hello,
This option is good but it would be perfect if you can even click in the specific object and Zooms to it:
http://prntscr.com/d81gc0
Thanks
Locating things
I see your idea,, but the point is that you cannot click inside a tooltip — such is a rule of interface controls and how they normally work in applications (not only in Wialon).
Hello,
I can show you 2 platforms that can it can make it.
Thanks
Regards
Locating things
17
locationGPS, please show us some examples.
