Object stopped but SW shows Moving state (green arrow)
Тема: Object stopped but SW shows Moving state (green arrow)
Hello,
I am having lot of problems with devices that has configured to show the movement by motion instead the Ignition connected to a wire.
The problem is always the same, the last coordinate can appear like the speed>0 so the SW shows the green arrow in the object and in the control panel.
As I experienced with other platforms, this is an old error that was filtered time ago but not wialon still.
Working in HW side is not possible as I should set to send 1 coord. x sec.;
As it was solved in other platforms was setting the device to change status from moving to stopped after X time (5-7 min.) when it is not moving and after it moves and sends the collected coordinates make a recalculation.
By now I tell clients that the place where is stopped did not have GPRs coverage but of course they do not care.
Help to solve it please.
Thanks
Locating things
Re: Object stopped but SW shows Moving state (green arrow)
locationGPS, the problem is clear. We'll consider implementing your suggestion, thanks.
thanks
Locating things
Now the period of time to display green arrows (movement direction) is adjustable.
Available in Beta.
Katerina Alexandrova
Product Manager (Mobile)
great
thanks
Locating things
Hello,
check image please:
http://prntscr.com/dd4qya
and in APP yes it appeas correctly: http://prntscr.com/dd4r9h
PLease check.
thanks
Locating things
locationGPS, it works correctly. Please check this documentation.
It doesn't say that after expiry, motion state changes to Stopped. It says that after expiry, motion state (whether Moving or Stopped) becomes dimmed (grey).
