DCT Antares
Тема: DCT Antares
Hi,
I would like to know if anyone has connected DCT Antares unit with Wialon server. If yes can you provide me the programming script.
I created my own script and connect it to the server, I can see the device transmitting data but there are many things I don't understand, for example, how can I create Ignition On/Off status, IO On/Off status.
Thanks in advance.
Murali
Kuala Lumpur, Malaysia
DCT Antares
Re: DCT Antares
murali пишет:
Hi,
Thanks in advance.
Murali
UKRGPS company do it. We have contract with DigitalCOMTECH and provide Antares.
www.ukrgps.ua
www.ukrgps.ua - профессиональные системы мониторинга транспорта.
+38 097 0033330
+38 095 0033330
DCT Antares
Re: DCT Antares
Hi,
I will be glad if you can provide me your programming script to make it work on Wialon server plus some guide on Ignition and IO settings.
Thanks in advance.
Murali
DCT Antares
Re: DCT Antares
murali пишет:
Hi,
Thanks in advance.
Murali
OK
Do you have device right now?
+38 097 0033330
+38 095 0033330
DCT Antares
Re: DCT Antares
Yes I do have the device with me but not Antares it's Syrus
DCT Antares
Re: DCT Antares
Do you still need help posting this device on the system
DCT Antares
Re: DCT Antares
aressun пишет:
It's OK we manage to get the correct programming script for it.
Thank you.
Murali
DCT Antares
Re: DCT Antares
Great then be carefull it is not a very reliable device, GSM hang up and the the GPS antena connector tends to fail it is not contructed properly.
till next time then
DCT Antares
Re: DCT Antares
murali пишет:
aressun пишет:
Thank you.
Murali
murali & aressun,
Glad you posted on this topic! I have Syrus devices that I'm looking to post on the system.
Should I use the Antares5 script found under GPS Hardware, or do you have a better programming script to provide me with?
Thanks!
DCT Antares
Re: DCT Antares
It all depends on what you call a better programming script , we have to be careful on how we use this device because it is posted on wialon with certain singularities..for example
EVENTS REPORTED
# EVENT 00 = IGN ON
# EVENT 01 = IGN OFF
# EVENT 02 = Desconexion de Fuente de Voltaje
# EVENT 03 = Conexion de Fuente de Voltaje
# EVENT 07 = REPORTE CADA 500 mts/15 grados, la condicion que se cumpla primero.
# EVENT 08 = Apertura 0
# EVENT 09 = Apertura 1
# EVENT 10 = Apertura 2
i am attaching the script we use so you dont get wrong information from the data center.
DCT Antares
Re: DCT Antares
Thank you!
Did you send the attachment? Is it a script to upload to my devices?
DCT Antares
Re: DCT Antares
give me your email to send
DCT Antares
Re: DCT Antares
rlsothermail_at_gmail_dot_com
Thank you!
DCT Antares
Re: DCT Antares
NO problem it si send just confirm that you recieved it
DCT Antares
Re: DCT Antares
aressun пишет:
Received - Thank you very much!
I will upload the script & use the port connection on the website and I'll let you know how it went.
Thanks.
DCT Antares
Re: DCT Antares
surfaty пишет:
aressun пишет:
Thanks.
Hi surfaty, please let me know how it works, the software (Wialon server) should detect Ignition On/Off with the key icon plus it should also detects all the IO (4 Input and 4 Outputs), external power removal and etc.
Thank you.
Murali
17
DCT Antares
Re: DCT Antares
Just remember that IGN is IN9 not IN1 and also
# EVENT 00 = IGN ON
But a really dont recommend this device, you can actually obtain better quality devices at a lower price around, one thing yes support is good
18
DCT Antares
Re: DCT Antares
aressun пишет:
# EVENT 00 = IGN ON
Hi aressun,
I don't want to argue with your statement, you have the right to speak. DCT devices especially the latest Syrus is one of the best in the world, our main or most preferred device is Syrus. Teltonika, Cellocator or whatever device you many know cannot beat Syrus's functionality and price. For me Teltonika FM42 is the worst.
Added after    9 minuts  23 seconds:
Furthermore Event code doesn't really need to be as above, we can have any Event code as we like. For example I use  Event 00 for ignition On and Event 69 for Ignition Off, the most important is how we program the Extended EV data.
19
DCT Antares
Re: DCT Antares
That is rigth all is a matter of opinion and how you configure it, and i agree that Syrus has a lot nice  functions this device is an upgrade from the Antares that gives so many problems. once you test the Syrus for enough time please tell me if they solved all the bugs that infested the Antares.
The script that i sent has the events programmed as i described......so surfaty has no problems identifying them
regards
20
DCT Antares
Re: DCT Antares
I have around 60 Syrus so far, only 3 units (the 1st batch I bought) had RMA issue, the rest looks good. I agree with you Antares has many problems.
We use RS232 fuel level sensor with Syrus, the result and accuracy is better than Teltonika FM42
21
DCT Antares
Re: DCT Antares
i would like to konw about the anti-jamming funtion in the syrus and how it works for example it is possible to turn off the engine if the syrus detect the jammer?
22
DCT Antares
Re: DCT Antares
it seems it does not: here is what we have in the manual as how it works
The Syrus is able to detect deliberate GPRS/GSM network interferences that could pose possible security risks. When a communications jamming status is detected, F23 signal  is set to true. This signal is intended to be used as a warning. If the jamming status is detected continuously for over a minute the G04 signal will be set to true. Using these signals it is possible to generate reports to notify this state. Needless to say, the reports can only be sent to the server once the unit is no longer under jamming conditions. The extended EV tag JO can also be configured so that it is included on each report generated when the unit was under jamming condition
Atrack A5(i) does do what you want and stops the engine when the condition of jamming is detected
hope it helps
23
DCT Antares
Re: DCT Antares
hi aressun can you send me the script please. mrmendivil@gmail.com
24
DCT Antares
Re: DCT Antares
its on your mail
regards
25
DCT Antares
(18/10/2011 21:21:23 отредактировано small_gprs)
Re: DCT Antares
aressun пишет:
Yep, as Antares upgrade the dino.Syrus isn't the more stable device now, firmwares are continuosly released to correct malfunction or adding new experimental features but i'ts a messy and endless loop.
mrmendivil пишет:
i would like to know about the anti-jamming funtion in the syrus and how it works for example it is possible to turn off the engine if the syrus detect the jammer?
Enfora's 2338 MTuG device has already Jamming detection years ago when Syrus was a Desktop project only !!, it has the most reliable jamming detection i ever seen on many Brands, and Yep Enfora's device can do many things once jamming were detected as output high one of its digital outputs to turn off the engine due the fact the internal event machine works with registers (like programming flags) and multiple user registers, counters and pre.made functions allows you to make almost anything you want , ALL these Enfora's function was emulated lately by Syrus programmers,
But, i have to say, I like the cinterion modules ( i think they are very first class) but as everybody knows, keeping backward compatibility (Antares-then-Syrus) is tooo messy.
Spread the AVL- World
