Flespi PHP or ANY CURL POST - Store Latitude and Longitude of device
Topic: Flespi PHP or ANY CURL POST - Store Latitude and Longitude of device
Hi,
I am developing a Mobile App and reading current location with latitude and Longitude.
I would like to send the location details to flespi using API curl(PHP).
Please suggest with an example.
Re: Flespi PHP or ANY CURL POST - Store Latitude and Longitude of device
Hello, you can use HTTP channel for that - https://flespi.com/protocols/http
all you need is just create a channel operated over HTTP protocol and send your request in the way like
curl -X POST -d '[{"ident":"1234","position.latitude":52,"position.longitude":48}]' 'http://gw.flespi.io:123456'
method: POST
data: json array of json objects. required field is ident string. other naming parameters may be custom (or take it from any protocol, like this is the list for Teltonika parameters - https://flespi.com/protocols/teltonika#parameters)
target: the URI of your HTTP channel
(edited by venujakku 31/10/2018 17:05:25)
Hi Thank you Very much for Quick response.
Can you please guide to how to find ident and Chanel values
curl -X POST -d '[{"ident":"XXXXX","position.latitude":52,"position.longitude":48}]' 'http://gw.flespi.io:XXXXXXXXXXXXX'
and How to pass the authentication token.
Thank you in Advance.
Sample Image attached my channel details. But , I am unable to understand http://gw.flespi.io:XXXXXXXXXXXXX
  • Flespi PHP or ANY CURL POST - Store Latitude and Longitude of device
venujakku, in channel you do not need token to POST messages.
gw.flespi.io:XXX => this is URI of your channel with http protocol.
ident - any custom unique device identifier
Hi,
I am using url like below
http://193.193.165.37:29983
But, Unable to connect the above url getting error message (Attached image)
I can share the https://flespi.com login and password details to resolve this issue.
venujakku,
You can post messages only to channel with protocol "http".
After you create this channel you will get its uri in format 193.193.165.37:SomePort
Then you may send messages using HTTP POST request to http://193.193.165.37:SomePort
Another thing is that you are trying to send data encoded as form-data (according your last screenshot) but this is wrong.
Please send raw data in JSON array format like in baja post: [{"ident":"1234","position.latitude":52,"position.longitude":48}]
You may note that it's possible to send several messages per one HTTP POST request.
Developer
flespi team
